Dodge Gas Predator Revision History
Locked
johan
Post by johan »
This thread will contain revision history of all our DCX gas Predators.
It will be open for viewing only, only moderators can edit this thread.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
johan
U7135
Post by johan »
U7135 history
r14
  • Release rev
rev r16
  • EGR disable (5.7L only) SRT8 does not have MDS
  • MDS disable (5.7L only) SRT8 does not have EGR
  • Rear 02 disable (2 params, 02 sensor on/off, 02 heaters on/off) need to turn both off in order for it to disable them.
  • Tunes improved for better lower throttle response
  • WOT fuel parameter fixed to adjust proper amount of fuel(did not adjust enough before)
  • Neutral rev limiter adjustment bumped up to max 5000rpms
  • WOT spark increment changed from 0.5 to 1 degree(s)
  • Tool will not allow a backup of a vehicle with a Predator tune in it
  • Changed "Cycle Key" to "Turn Key Off/On" message
rev r17
  • Fixed screw up(by me) in quick adjust parameters:
  • SRT's had shift firmness in them, removed now as it does not do anything
  • 06 5.7L did not have shift firmness in them, added that as it does do something
  • Renamed Perfromance tunes, to Perf 93oct as people did not know which one was the 93 octane tune.
  • Removed the -/+ in the WOT fuel adjustment so it will just start at zero and numbers will go up either way you go on the scale towards rich and lean.
  • Added export and police calid support, NOTE: These calids only have 2 tunes , Perf93 and Perf93 CAI
  • Live data display and log implemented
  • Added early05 (SCI) support, NOTE: For Q&A to work they need to update to latest TCM flash as early flash does not support that feature, plus autostick upshift is removed as it was not supported either in the early 05's
  • 07 SRT8's have the autostick upshift disable parameter in them, BUT it does not work like the 05-06's, when disabled it will not allow vehicle to shift past the commanded gear but it will downshift to a lower gear and shift back up to commanded based on throttle input, we mainly left it there for dyno use.
rev r18
  • Idle surge fix, all cals
  • removed knock sensor disable
  • Added MBT spark table adjust
  • Added support for 06 jeep SRT8, 05030369AC
  • Fix for live data upload crash
  • Fix for 06-07 5.7L autostick disable/enable
  • Removed autostick feature for 07 SRT8 as it did not work properly
rev r19
  • Support for 08 vehicles
  • Support for new 07 calids, customer with R18 or earlier will be asked to do a calibration update to update to new 07 calid's
  • ALL tunes revised, changed wot fuel, raised fan temps and firmer shifts(5.7L only)
  • Forced induction checksum fix implemented
  • Fix for live data view in Predator
  • Axle ratio change added as quick adjust
  • This new revision will be using rev3 files as indicated in the header, failure to use a rev3 file and creating level 2 changes (forced induction) in CMR can result in a limp PCM, the key in start position will be necessary to recover.
  • Jeep AWD fix implemented, TM configs set back to stock but one
  • NOTE FOR TECH: if message "invalid calibration update file (1)" comes up, means that they need to update to r19
rev r20
  • Fix for import of unsupported calid custom tune before taking a backup
  • rev 9r01
  • Hardware update, fix for disable rear 02's, fix for custom tune import before original backup, fix for calibration update for early 05's
rev 9r02
  • Internal update, NO OTHER CHANGES
rev 9r03
  • Support for new 06 and 08 calids,
  • QA parameters edited to allow more choices for shift points and autstick disable.
  • More axle ratio choices added.
rev 9r04
  • Fix for QA adjust right after backup is taken where the menu would stay on the key cycle screen
rev 9r05
  • No changes to tunes or support, internal update for production
rev 9r06
  • Added support for new 06 5.7L calids
  • Added support for unsupported 08 Jeep SRT8
  • ALL tunes tweaked for better launch and improved mpg
  • SRT8 car tunes tweaked for better wot shifts
  • Shift points removed for the 08's, did not work properly
  • ESP mode changed to Dyno mode
rev 9r07
  • Fix for labels in the Dyno mode change done in r06
rev 9r08
  • Fix for 06 calids added not showing modify factory tune and original backup.
rev 9r09
  • Added support for new 2008 5.7L calids
  • Added 3.28 and 3.33 axle ratio selection
rev 9r10
  • Jeep tunes redone
rev 9r11
  • Fix for tire size adjustment freezing up
rev 9r13
  • Support for 2009 SRT8 Charger/Challenger/300 and Jeep GC with automatic transmissions ONLY
rev 9r14
  • Support for 2008 export Jeep
rev 9r13
  • Support for 2009 5.7L auto/manual, 2009 6.1L manual, 2006 jeep GC export, 2 new 2008 LX calids added.
rev 9r14
  • Support for 2008 Export Jeep
rev 9r15
  • Support for 09 5.7L, 09 SRT8 manual transmission, 06 Japanese GC,05030429ab, 2 new 08calids,68045991ab,68045990ab
rev 9r16
  • Fix for 09 5.7L fuel adjustment not working, revised the manual tranmission tunes for slow decel fix.
rev 9r17
  • Added support for 68061225AA , revised the 09 srt8 M6 tunes for a 3rd gear torque limiter.
rev 9r18
  • Added support for 68061220aa and 68061224aa.
rev 9r19
  • Added support for new 2009 calids and fixed custom parameters for some 2009's.
Diablosport INC
johan
U7136
Post by johan »
U7136
rev 9r01
  • Release rev
rev 9r02
  • Fix for idle surge and hanging rpm decel
rev 9r03
  • Added support for new 07-08 calid's
rev 9r04
  • Added support for new 08 calid's as well as 2009 MY support
Diablosport INC
johan
U7137
Post by johan »
U7137
rev 9r01
  • Release rev
rev 9r02
  • Support for new 04-08 calids
  • Tunes revised for better shifts, 04-08
  • Key cycle fix when adjusting tire size
  • RPM shift point adjustment fixed
rev 9r03
  • ALL tunes revised for better transmission performance.
rev 9r04
  • Added support for 07-08 Jeep GC, Jeep Commander and Dodge Durango with the 5.7L Hemi.
Diablosport INC
Locked
