Diablo tune
Diablo tune
I installed the diablo tune from the diablo intune i3 8245 for GM vehicles and was wondering if I should be running 93 octane fuel instead of 87 octane ?
Re: Diablo tune
YES!!! The "Diablo Tune" is a high-octane tune... you have to be using 91-93 octane gas in the vehicle to use the "Diablo Tune"!!!
If you're only using 87/89 octane gas in the truck, then you need to select/install the 87 Octane Tune...
Re: Diablo tune
Ok thank you I thought the diablo tune was a flex tune and could run on any grade fuel as the vehicle has a flex fuel sensor ...
Re: Diablo tune
No.....Kevin33 wrote:Ok thank you I thought the diablo tune was a flex tune and could run on any grade fuel as the vehicle has a flex fuel sensor ...
Re: Diablo tune
So I’m assuming running E85 is not an option also ?
Re: Diablo tune
If your GM vehicle is a factory Flex-Fuel vehicle, yes you can... and will get worse gas mileage from the e85.... if your GM vehicle is NOT a factory flex-fuel vehicle, then no, you can't run E85.....
Re: Diablo tune
Yes it’s factory flex fuel ..Ok so what I’m getting at is since I loaded the diablo performance tune and it’s a high octane tune I can actually run E85 but will get worse gas mileage correct?
Re: Diablo tune
I’ve already set my throttle boost to the max 20% on the diablo 8245 tuner ,Will a K&N throttle control module give me more added throttle response ?
Re: Diablo tune
Can i use "diablo tune" on my 2017 Camaro ss on 91 octane. or is it only for 93 oct only?
Re: Diablo tune
On that car the Diablo Tune is for 93 octane gas.dz1le wrote:Can i use "diablo tune" on my 2017 Camaro ss on 91 octane. or is it only for 93 oct only?
Use the 91 Octane tune if you use 91 octane gas.
Re: Diablo tune
06MonteSS wrote:If your GM vehicle is a factory Flex-Fuel vehicle, yes you can... and will get worse gas mileage from the e85.... if your GM vehicle is NOT a factory flex-fuel vehicle, then no, you can't run E85.....
what if i have a 2018 silverado non flex fuel and installed the flex fuel sensor and already have the diablo tune can i run flex fuel or would i need to get a custom tune for the ecu to be able to run on flex fuel
Re: Diablo tune
you need a custom tune to enable the sensor and ideally to populate the flex side of the cal.
Re: Diablo tune
can u help me with adding those things to the tune i currently have?mikel wrote:you need a custom tune to enable the sensor and ideally to populate the flex side of the cal.
