Predator 2 and intune bad luck
I just purchased the predator 2 7201 for my 2009 Corvette and I got a calibration message. And also I've tried to remove my i1000 from the car and it froze up. Now I have a check engine light on
Re: Predator 2 and intune bad luck
and may i add that i have a 2009 chevy silverado that the predator 2 will program
- MagsTuning
So the i1000 freezes when trying to return to stock?
Have you checked the code(s)? What's it showing?
after i turn the key on. the little spinning thing spins about two times and it stops spinning. it does that even when i try to use the scan tool
first thing Id suggest is updating the i1000 with update agent then try the restore again.
the P2 is going to see the previous tune and prompt you to contact us to get it back to stock unless you restore it with the i1.
