2016 Camaro SS AFM
Posted: Mon Jan 06, 2020 4:55 pm
by Jvcamaro6
Hello, I have a Trinity T1000 with 1R14B revision on it. I uploaded a 91 Octane tune with a hard shift trans tune, but it doesn’t seem to turn off my AFM? The light goes green and shows V4 mode still, I tried with a modified stock tune and it does the same thing. Do you know what’s going on? Thanks
Re: 2016 Camaro SS AFM
Posted: Mon Jan 06, 2020 5:53 pm
you are selecting the option for AFM off then installing the tune after that?
if souse the DSDownloader to export the last tune written and post it here.
Posted: Mon Jan 06, 2020 5:59 pm
it doesn't get disabled automatically man... you have to select to Modify the 91 octane tune and disable the setting yourself, and then install the tune...
Posted: Mon Jan 06, 2020 6:06 pm
by Jvcamaro6
I am modifying the tune and selecting AFM/DOD off in the engine parameters. I have changed the tune 3 times to try and see what the problem was. Still goes into V4.
Posted: Mon Jan 06, 2020 7:48 pm
by Jvcamaro6
PCM_673677677821_Modify_Stock_Tune_modified.grg
(3.25 KiB) Downloaded 435 times
Posted: Mon Jan 06, 2020 7:50 pm
by Jvcamaro6
TCM_281915281926_Trans_Hard_Shift_Tune_modified.grg
(11.25 KiB) Downloaded 448 times
Posted: Tue Jan 07, 2020 12:56 pm
I dont recall f this was a bug on that application, but it was not off.
Load the attached custom tune and it will be disabled.
Posted: Tue Jan 07, 2020 2:07 pm
by Jvcamaro6
Thank you so much highly appreciated!
