Add Fan Settings to Quick Adjust menu
Posted: Sun Jun 29, 2008 12:11 am
Just an item for the wish-list:
If possible, could the Cooling Fan parameters be added to the Quick Adjust menu? That would be especially beneficial for those of us running cooler thermostats.
It is a fairly common practice for us cooler T-Stat guys to bump up the Fan temps every couple of weeks so we can get the oil temp over 212 -- just to flash off water and contaminants.
Also regarding the Fan settings....I found when I set the temps for the Fans to come on, install the changes, and go back to check the Fan temps again -- they are 2 degrees less than what I set. If I set for low speed to come on at 185^, I go back to check and the low speed is set to come on at 183^. This is with all the Fan settings -- both AC on and off. Any ideas why this would happen?
Phil C.
Phil C.
