I just traded in my 2014 ram , im looking too tune my 2018 ram , I see there now a harness that needed to bypass to get to the pcm . Do I install the bypass before installing the unlocked pcm .
Also can I use my i2 tool or should I buy the i3 ?
Lastly can when I buy an unlocked pcm for my 18 can I send in my 2015 locked pcm as a core. Would like to keep my 18 locked on for warrenty issues
2018 ram
Amermuscle
Re: 2018 ram
Getting ready too order , I cant find the bypass cable to add to my cart for the i3 and pcm . Also I noticed that my pcm has the module p/n and module s/n ..
The diablo example shows the module p/n then the vin under . Do I just do thebp/n and grab the vin someplace else and forget the s/n
Amermuscle
Re: 2018 ram
Curious if I could call over the phone to place my order so the numbers are correct
Re: 2018 ram
There should be images on the order page that show you where to find them on the PCM label. If not, you can absolutely give us a call on Monday to place the order over the phone if you’d prefer.
