MDS switch not working
I just installed my new t2 in my 2016 ram and as i was trying to change the parameters for the 91 tune it doesn't let me change the MDS switch to off and also the pedal sensitivity isn't letting me adjust it. I did update out of the box.
Re: MDS switch not working
can you post the info.xml file from the device here so we can check t out?
its on the T2 drive when you connect it to a pc.
file:///Volumes/t2/info.xml
