I have a 2022 Challenger with the 6.4. A local guy has an unlocked PCM and Trinity2 he removed from his 2019 Challenger with the 6.4. 1. Can I use this PCM at all. 2. How would Go about getting it set to the new VIN? Will the trinity do this on the stock read set up with the security bypass cable? Or is this a send it in thing. If it’s a send in thing how much would that cost? 3. Will the Trinity 2 need another license for the new VIN on the unlocked PCM?
Thanks for any help.
RE USING PCM IN DIFFERENT CAR
Re: RE USING PCM IN DIFFERENT CAR
you can send the pcm here to be revinned for $100, I believe the 19/22 use the same pcm.
set the t2 back to stock on the current vehicle to unlock it so its ready for use with the new vehicle.
