problems with cmr and programmings
my chip delta had the following 2 programmings tune 1 w4h0stml.cry = 0 ticks tune 2 w4h0s11d.cry =120 ticks and switch-on-the-fly enabled now do not appear to me ticks available when I put my chip in cmr and it only lets to me put programmings to it without cost as u4p0perf.cry and not even leaves to program with 120 cost of ticks the previous ones me that tapeworm only puts to me automatically in tune1 and tune 2 the same u4p0perf.cry and when I check what has the chip says that u4p0perf.cry has programmed switch-on-the-fly (enabled) tune 1 =0 ticks tune u4p0perf.cry =150 ticks what happen with my ticks? and so that it does without giving me options to put 2 different programmings although are without cost
claytonracing
RE: problems with cmr and programmings
I don't think you can use delta chips with CMR
Re: RE: problems with cmr and programmings
[quote="claytonracing"]I don't think you can use delta chips with CMR[/quote] :oops: i don now the name ? if dont is cmr wath is the name . in the machine say web-rady-tick-counting read-write-machine and is similar at the cmr sorry
