Want to remove my tune but...
Justardnck
Post by Justardnck »
I hate my 87 octane tune, it makes my truck surge at idle and the idle is so low the truck is constantly stalling, this is something that has NEVER happened before the tune. I need to keep my speedo cal so is there a way I can calibrate my speedo without using any tuning other than the speedo tune?
2003 GMC 2500HD 4X4 6.0L gas guzzler
CANUCKPREDATOR
RE: Want to remove my tune but...
Post by CANUCKPREDATOR »
You can restore your factory tune and then modify the factory tune. I'd look into some other things first though. Is you air intake ok? Everything connected, no holes, leaks? Any vacuum leaks? Exhaust system ok? Any service engine lights? Use the Predator to check for codes.
Justardnck
Re: RE: Want to remove my tune but...
CANUCKPREDATOR wrote:You can restore your factory tune and then modify the factory tune. I'd look into some other things first though. Is you air intake ok? Everything connected, no holes, leaks? Any vacuum leaks? Exhaust system ok? Any service engine lights? Use the Predator to check for codes.
The engine had absolutely no issues before the tune and immediately after the tune started having issues. I tried running the truck for a week to see if the issues would work out but that didn't happen. Personally I don't care about losing the tune but the reason I bought the Predator was to recal my speedo. I put the 87 octane tune in because I thought it might help but it hasn't changed a thing except that the truck runs worse at idle.
Justardnck
Sorry, I didn't answer your question. There are no intake or exhaust leaks, the K&N filter has been cleaned recently and no check engine lights are on.
RE: Re: RE: Want to remove my tune but...
That is odd, but yes, you can use the modify stock tune to change tire size and nothing else..
Justardnck
Re: RE: Re: RE: Want to remove my tune but...
mikel wrote:That is odd, but yes, you can use the modify stock tune to change tire size and nothing else..
I will try that, I didn't know I could do that. I thought I had to install one of the standard tunes to change the speedo.
johan
RE: Re: RE: Re: RE: Want to remove my tune but...
Post by johan »
What revision do you have on that predator?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Justardnck
Re: RE: Re: RE: Re: RE: Want to remove my tune but...
johan wrote:What revision do you have on that predator?
I don't know, there is a small sticker on the back that says 182856 The box has a big br code : 6 89076 34017 5
It is a U7195
Do any of those number help?
RE: Re: RE: Re: RE: Re: RE: Want to remove my tune but...
Revision is shown on the top line of the main menu.
07Silvy
Post by 07Silvy »
I bet that you over oiled your K&N. Happens all the time. If so, your MAF is covered in oil and can not read the incoming air correctly.
CANUCKPREDATOR
07Silvy wrote:I bet that you over oiled your K&N. Happens all the time. If so, your MAF is covered in oil and can not read the incoming air correctly.
Never thought of that, could be. You will have to remove the MAF from the intake tube and use a good cleaner on it. Pretty easy job to do. Couple of hose clamps and wire harness and your good to go.
I second that idea....
