preadtor 2 issues
Discuss Predator 2 for Chrysler vehicles
preadtor 2 issues
Post by [email protected] »
brought predator 2 updated first before using , connected to car now tells me no files found , device info tells me needs update , update agent tells me device is up to date but also says vin lock needs update,installed package r311 (no files ) cant do anything only check codes and temp etc... no tunes,
it looks like I might have managed to download files however when I connect to udate agent I am still getting same messages as above, I connect to vechile now its telling me my vechile is not supported mmmm
the only way I could get files to download was to remove checksum first from device info any help is appreciated
DEVICE LOG
CSR,[INFO] ,Log_App_FWName,975,Dodge GPECII Firmware:57
CSR,[INFO] ,Log_App_FWName,979,IAP Version:23
CSR,[INFO] ,Log_App_FWName,983,VehicleID Version:14
ENG,[INFO] ,Read_Vehicle,374,Identifying the Module Type
ENG,[INFO] ,ID_Protocol,1162,:2C 0D 0A 09 34 90 06 08
ENG,[INFO] ,ID_Protocol,1163,:04
ENG,[INFO] ,ID_Protocol,1162,:BB DF FF FF 26 FB 01 20
ENG,[INFO] ,ID_Protocol,1162,:42 30 41
ENG,[INFO] ,ID_Protocol,1163,:00
ENG,[INFO] ,Prompt_Ignition_On,294,Ignition On Detected
ENG,[INFO] ,Id_GPECII_Vehicle,471,:87 02 36 23 A4 FF 12 47 10 01 00 36 38 30 37 38 36 33 38 41 45
CSR,[INFO] ,Read_Vehicle,429,VIN:2C3CDYAG5CH121297
CSR,[INFO] ,Read_Vehicle,431,PartNumber:68078638AE
ENG,[INFO] ,Read_Vehicle,484,Engine VIN Number Saved
ENG,[INFO] ,Read_Vehicle,604,Begin Read of Stock File
ENG,[ERROR],Read_Vehicle,676,Tuner Requires an Update
ENG,[INFO] ,ID_Protocol,1162,:37 20 31 30 34 90 06 08
ENG,[INFO] ,ID_Protocol,1162,:42 30 03
ENG,[INFO] ,Transfer_Data_Up,1748,CAN_Request response:03
ENG,[INFO] ,Transfer_Data_Up,1749,CAN response data:98 0D 29 32 9B3A 53 E0 0F 7C 54 00 06 3E 53 E0 07 FE 98 0D 29 3A 9B
ENG,[ERROR],Read_GPECII,796,Transfer Request Failed
ENG,[INFO] ,ID_Protocol,1162,:42 2E 81
ENG,[INFO] ,ID_Protocol,1162,:49 49 5F 56 34 90 06 08
ENG,[INFO] ,ID_Protocol,1162,:42 2F 0C
ENG,[INFO] ,Transfer_Data_Up,1749,CAN response data:A1 71 86 4E 5501 00 14 88 6D 19 75 54 63 E7 FF 41 82 00 08 48 00 06 BD 88
ENG,[INFO] ,ID_Protocol,1162,:65 71 FF FF 26 FB 01 20
ENG,[INFO] ,ID_Protocol,1162,:42 2F C5
ENG,[INFO] ,ID_Protocol,1162,:42 2F 97
ENG,[INFO] ,ID_Protocol,1162,:42 31 19
ENG,[ERROR],Id_GPECII_Vehicle,455,Not a Ram, Jeep, Challenger, Charger, or 300
ENG,[ERROR],Ask_If_Diff_DCX_Vehicle,1030,Ignition Not Detected
ENG,[INFO] ,ID_Protocol,1162,:42 2F 87
CSR,[INFO] ,Vid_Version_Hex_to_Ascii,1376,VehicleID Version:0017
ENG,[INFO] ,Identify_Vehicle_Coms,374,CAN Protocol
CSR,[INFO] ,Identify_Vehicle_Coms,406,VIN:1C3H9E3H77Y526648
ENG,[ERROR],Get_Application_File,1101,VIN Not found in xml
ENG,[ERROR],Get_Vehicle_Application,1054,VIN Not found in xml
CSR,[ERROR],Identify_Vehicle,346,No Application Software For This Vehicle!
ENG,[INFO] ,Identify_Vehicle_Coms,397,Unknown Comms Protocol
ENG,[INFO] ,Identify_Vehicle_Coms,402,No VIN
ENG,[INFO] ,Get_User_ID_Mnfctr,613,User selected DODGE-JEEP
CSR,[INFO] ,Log_User_Vehicle_Selection,1419,User selected:07-10 Chrysler 300
CSR,[INFO] ,Log_App_FWName,975,Dodge NGC4 Firmware:58
CSR,[INFO] ,Log_App_FWName,983,VehicleID Version:17
CSR,[INFO] ,Dig_Voltmeter,286,12.8
ENG,[INFO] ,Read_Vehicle,201,Identifying the Module Type
ENG,[INFO] ,Read_Vehicle,216,Vehicle Comms Started
CSR,[INFO] ,Id_NGC4_Vehicle,41,Vin Number Connected:1C3H9E3H77Y526648
ENG,[ERROR],Id_NGC4_Vehicle,501,Vehicle is Not Supported
ENG,[ERROR],main,226,Decoding update.cfg.
CSR,[INFO] ,Display_Gauges,73,Available PIDs :BFBEB993801FA019FED0000000000000
CSR,[INFO] ,Dig_Voltmeter,286,12.1
Re: preadtor 2 issues
contact tech support for the needs update situation, your cal is not on file in our database.
I just got an email from them they say rhd/ export vechile are not supported.. great
I'm in Australia
Ahh, yes.inTune 3 will work. 8345.
To late now just spent $1000
Are you 100% that it will work on a 2007 Chrysler 5.7 hemi .. RHD / export in Australia. And will it turn mds off and fan adjustments
Last edited by [email protected] on Tue Feb 21, 2023 6:32 am, edited 1 time in total.
How about swapping if for me then ??
I am sure it will work.
Where did you purchase the Predator 2?
Rolan. Australia they sell all your products and sold it to me as a working tuner
Last edited by [email protected] on Tue Feb 21, 2023 5:11 pm, edited 1 time in total.
Ihave been reading old threads with the same problem back in 2010 you fixed there problem with updates etc but now in 2023 you can't fix mine .. same issue, same country ( australia )
[email protected] wrote: Tue Feb 21, 2023 8:22 pm Ihave been reading old threads with the same problem back in 2010 you fixed there problem with updates etc but now in 2023 you can't fix mine .. same issue, same country ( australia )
there was no such thing as a P2 in 2010 :) Any issue you noted must have been on a different platform, which makes everything different.
I am not aware of any solution to make this work for you in this case short of going to i3 or T2.
Your support officer Christina Petri is telling me i3 might not work as it been hit and miss with export vechile just don't want to spend more $$ and find it won't do the job
I can confirm the i3 or t2 will work. I have verified support for your specific calibration ID based on the info you pasted previously.
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
