Traction Control Parameter with Asterisk for 2003 Cobra
da28fan
Post by da28fan »
I updated my Predator with the recent firmware upgrade. My traction control parameter has an asterisk in front of it and I can't seem to change it. On the old program, I could turn off traction control all the time instead of having to hit the button each time. Now I can't seem to do that. Can you tell me what the asterisk means on the menu and if I can still turn off this feature? (I'm using the 92 octane performance tune). Thank you.
U7142
#144550
2003 Cobra
v.7r12d (w 9r02 update)
concoursd
RE: Traction Control Parameter with Asterisk for 2003 Cobra
Post by concoursd »
that is strange. usually the asterisk means that you have changed the parameter. Have you tried to reset the parameters in the predator? That should remove all astericks.
sohfast94
Post by sohfast94 »
Or you could highlight that parameter and hit the center button and it should bring you to the menu for it to turn it on or off. Either way.
Insert Clever comment here...
Return to “Predator Ford Gas”
