denali 6.2 tuning
uky2000
denali 6.2 tuning
Post by uky2000 »
ok what i have to do to get more hp on 93 octane gas and how much hp will inc ,,,,,,
what i did just install diablo tune .i didn't do any thing else only turn off speed limits and inc rev limits is that ok
my car is 07 gmc denali
concoursd
RE: denali 6.2 tuning
Post by concoursd »
get a pc interface kit if you dont already have them (you can buy the cable and power adaptor locally at places like radioshack). Then read the stickie threads at the top of this forum on how to datalog with your predator and use the DSLogRedux software.
This will give you recommendations for how to adjust the fuel and timing to for optimal performance. Then repeat the process to verify your changes. This will help to dial in your tuning based on how your actual vehicle responds to the gas quality you have etc.
ches111
Post by ches111 »
Here is the sticky he is referring to.. It is telling you how to set your LTFTs or Long Term Fuel Trims..
After this you will feel quite boost and and will likely get better gas mileage.
http://www.diablosport.com/index.php?na ... opic&t=917
You don't need the interface kit to do this.. But it does help get a larger set of data points which helps with accuracy..
07 Chevy Silverado w6.0L Vortec Max, U7194, AEM Brute Force
uky2000
Post by uky2000 »
do i have to do all that i mean diablo tune is not enough
yukon denali 6.2 with k&n air intake sys+corsa exhaust sys+diablo tune
08 Corvette zo6 with k&n cai+corsa exhaust sys+diablo tune
09 mustang gt waiting for predator
05 mustang gt with P-1SC-1 procharger
ches111
Post by ches111 »
You can just do more.. That is all.. The diablo tune is good the dial in is better..
Up to you if you would like to leave it at that.
Really is not as complicated as it sounds.
For instance you can have someone monitor your LTFTs as you drive. Just start the engine and plu the predator into its port. Then open the predator for diagnostics/logging and look at the realtime data.
after getting an average at a stady 1800 to 2500 RPMs then come on here and tell us what your average was for both banks..
No PC required. Then we will help you set the injector slope to bring it in line more.
uky2000
Post by uky2000 »
ok that what i found ches111
14.5 air fuel ratio
0.78%long bank 1
0.78%bank 2
41.00 spark adv
at 2000 rpm
ches111
Post by ches111 »
is that .78 an average? or is it a one time look?
If it is the average over that RPM range you can change injector slope -1 and you should be dialed in..
That easy...
You will have to drive 50 miles or so for it to fully take affect but after that you should be good.
You were already pretty close to where ya needed to be...
uky2000
Post by uky2000 »
idon't know man first time i have diff reading how can i know the average
send me ur email as pm then i will send u photo
yup, go -1% on injector slope setting...
it won't always be the same, every time... but when you go for a steady drive/cruise, see what your bank 1 and bank 2 LTFT's are reading....
get an average for each bank...
and do it in the warmest/hottest time of the season for your area...
once you find that average, adjust your injector slope appropriately, and you'll be all set.
ches111
Post by ches111 »
If you are logging in realtime (do not have to keep the log) just watch it for a few seconds every now and again..
or better yet have someone else watch it...
Then take an approx average...
Should become pretty obvious.. If you are locking in at ~0.78 then just move injector slope -1 and you will be done..
uky2000
Post by uky2000 »
thank's guys i am in dubai it's like 125f
one more qustion what about cot adjusment
if you still have catalytic converters on your vehicle, leave it alone...
if you don't, then you can turn it off / disable it...
uky2000
Post by uky2000 »
thank's guys
