i want more power..u7170
u7170 7r19dz calid VRAA7S5 .....2001 f250 pstroke73,,i do have the one with the smaller memory.just curious if there were any new updates . it feels like the 80 hp setting is stronger than the 100hp.. smokes badddd...is this to be expected?if u have an update email me one ..thanks...
RE: i want more power..u7170
I was just checking to see if you guys were able to come up with anything. I would like to see the full potential of the product ..80 does good.so im thinking the 100 or whatever size it is , should be a lil better.lemme know
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
I could have swore I sent you a file already.
Insert Clever comment here...
i was sent the 7r19dz..but thats it..i talked with mike and he said you guys might could help me.
Email Sent. 110hp
thank you..i will give it a shot..
RE: r19dz
i got the file ...now ...3 hrs..a new $40.00 cable.later..i cannot for the life of me get this pos of a computer to talk to the programmer..anyone else have this problem..it for dang sure worked the last time..only diff this go-round it has the 7r19dz in it..im running xp..i have tried the baud rate ,,,port settings..im lost..
Re: r19dz
It's a custom file. I can send any that you may like the .crom will be done shortly.fordtech wrote:Is this only new for 110 or is the whole crom new?
Re: RE: r19dz
On "auto-detect" is DSDL detecting the predator? I assume not. What type of USB to serial converter are you using?jbeasts10 wrote:i got the file ...now ...3 hrs..a new $40.00 cable.later..i cannot for the life of me get this pos of a computer to talk to the programmer..anyone else have this problem..it for dang sure worked the last time..only diff this go-round it has the 7r19dz in it..im running xp..i have tried the baud rate ,,,port settings..im lost..
RE: Re: RE: r19dz
this thing is acting all kinds of stupid..the only thing that has changed is the new crom..i have the 7170..it came with the 8r05..now has the 7r19dz..i have tried the old cable and reinstalled the driver like 6 or so times..bought a new version of the same from radio-shack.# on the driver cd is 26-949 ..i even tried loading from my wifes pc which uses vista..the cd does give the driver..nothing,,i was able (1) time to pick up some sort of communication using the hyperterminal or whatever its called....i have tried auto-connect..ive tried going through legacy ..i cant get any visibility from predator to dsdl..i have moved the port setting so much i cant remember what went where,,way to stressfull..about ready to send it to you guys and let you all fix it.
RE: Re: RE: r19dz
should i try the custom tune installation instructions? extract a copy of orginal back-up and then try to install custom tune.i have done exactly as said in the email..
RE: Re: RE: r19dz
Try the custom tune instructions.
RE: Re: RE: r19dz
i was thinking guys.if i could lean up the fuel a lil..(ok alottt)...add the 110hp tune.might be able to turn over these 285's..32lbs of boost aint nothing to sneeze at..just wish it wasnt so fat..help me cram this file in .
RE: Re: RE: r19dz
The fueling has been turned down. Just load the file and tell me what you think.
