05 Magnum R T
Discuss Predator 2 for Chrysler vehicles
Karp
05 Magnum R T
Post by Karp »
Alright, 05 Magnum R T. Stock 5.7 nag 5 speed automatic. Changed the rear differential from 2.82 to the GETRAG 3.06. my mechanic works at a Chrysler dealership. Cannot get the TCM to accept the change. Bought the Diablo Predator 2. Still cannot get it to accept the change. Trans goes to limp mode. Nothing was wrong with the car to start with. Help
Re: 05 Magnum R T
Well, if the factory tools wont work, and our tool doesnt work, it may point to the car itself. I assume it still has the stock/original EGS52 TCM?
Karp
Re: 05 Magnum R T
Post by Karp »
The car is stock . No issues with the car for the last 10.000 miles. Just a gear change.
Karp
Re: 05 Magnum R T
Post by Karp »
The only code it shows is P0700, 731,732
Karp
Re: 05 Magnum R T
Post by Karp »
Is there a better TCM available?
Karp
Re: 05 Magnum R T
Post by Karp »
I have checked connections on trans and TCM , removed and reconnected. Everything looks good, all wiring looks good, I double checked ratio of differential to be sure it is the 3.07. Where do I look next.
Karp
Re: 05 Magnum R T
Post by Karp »
It's a 3.06 that's the problem. No program for it. How cool would it be if this would have worked. :(
Re: 05 Magnum R T
Karp wrote: Wed Jul 05, 2023 12:37 pm It's a 3.06 that's the problem. No program for it. How cool would it be if this would have worked. :(
so what is the exact problem? the device does not present a 3.06 option? Is there anything close?
Or it lets you pick 3.06 but fails to make the change?
Karp
Re: 05 Magnum R T
Post by Karp »
The device does not offer the 3.06 it offers a 3.07. and that doesn't work
Karp
Re: 05 Magnum R T
Post by Karp »
I have tried adjusting tire size in 1/2 inch increments. Thinking I might find a happy spot but no love. Thanks
Re: 05 Magnum R T
Karp wrote: Thu Jul 06, 2023 5:56 am The device does not offer the 3.06 it offers a 3.07. and that doesn't work
OK, what exactly happens when you pick 3.07? That should work perfectly fine in reality.
Karp
Re: 05 Magnum R T
Post by Karp »
As soon as the vehicle reaches about 10 mph. Trans goes limp mode code p0731
Karp
Re: 05 Magnum R T
Post by Karp »
After initial setup I have full control of the transmission with the paddle shifter until approx 10 mph
Re: 05 Magnum R T
Karp wrote: Thu Jul 06, 2023 10:35 am As soon as the vehicle reaches about 10 mph. Trans goes limp mode code p0731
is the behavior the same when gear ratio is returned to stock value?
Also, when you go into the menu after programming it for 3.07, does it show 3.07 highlighted with * on the screen?
Karp
Re: 05 Magnum R T
Post by Karp »
Yes a stock value it does the same. And it says gear is modified when installed. Speedo adjusted.
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
