Hi ,, Pleas give the best option tune of diablosport Predator for Mustang 99 V8 Manual transmission ,, e.g - What is the best choice of timing, fuel table ........ ??
Modded : - Underdrive pulley
- H-pipe + Flowmaster mufflers
- 3:73 Ratio
- Aluminum driveshaft
What's the best option ?
Re: What's the best option ?
The only modification you will need to make in the Predator is to adjust the gear ratio to recalibrate the speedometer. The timing and fuel tables are already optimized for your current combo of parts in the provided performance tune.Trust wrote:Hi ,, Pleas give the best option tune of diablosport Predator for Mustang 99 V8 Manual transmission ,, e.g - What is the best choice of timing, fuel table ........ ??
- 3:73 Ratio
Hi ,,mikel wrote:The only modification you will need to make in the Predator is to adjust the gear ratio to recalibrate the speedometer. The timing and fuel tables are already optimized for your current combo of parts in the provided performance tune.Trust wrote:Hi ,, Pleas give the best option tune of diablosport Predator for Mustang 99 V8 Manual transmission ,, e.g - What is the best choice of timing, fuel table ........ ??
- 3:73 Ratio
Ok,, but if I want change the fule and the Spark ??
RE: Re: What
There is no need to adjust these as they are already adjusted in the tunes provided.
