Does the puck or preditor raise fuel rail pressure? If so what would the normal pressure be at 70 mph no load?
eg. if stock is say 15000 psi at 70 mph how much higher will the puck run the rail pressure to? Also does it commonly reach the bypass limit of 26000-27000 psi?
I am asking this so I can make smarter choices about what levels to use for different driving conditions. I do not what to kill the life of my CP3 pump if a little info can help me extend it's life.
Thanks in advance,
Darryl
Power puck fuel rail pressure?
djensen9367
On one of the other forums one fellow said the highest pressure he saw was 23500, well within the safe limits, that was on two of the higher settings.
2006 3500 quad (bighorn), 3.73 w/ auto, dunrite triple,qzilla std., amsoil nano filter,Donaldson 51". Airride 5th wheel, airride receiver hitch, jacobs brake, brakesmart ,35' Newmar 5th wheel, pace 14' ,GDP Gfs-392 Walbro w/2 Micron Filter
