Read a backup from vehicle FAILED
Ak4712345
Post by Ak4712345 »
2013 dodge ram 1500 5.7 Just got the intune i3 did all the updates it asked, plugged it into my computer registered device last night. Go to tune today plug into my truck says it needs to update so let it do that. Click easytune 91 octane says. “The i3 will now read a backup from the vehicle. Tap yes to confirm or no to abort”. I click yes and then this comes up - “read failed”
Tried like 10 times. Any suggestions?
Ak4712345
Re: Read a backup from vehicle FAILED
Post by Ak4712345 »
most likely previously tuned by something else that changed the bootloader, give us a call to sort it out, 561-908-0040
Brucecopebass
Post by Brucecopebass »
What is the Fix for this issue? I just received mine and it reads the backup till 64% then come up with this..... There has been no other tuner and its on a 03 suburban 1500 5.3
Brucecopebass wrote: Thu Jun 04, 2026 6:38 pm What is the Fix for this issue? I just received mine and it reads the backup till 64% then come up with this..... There has been no other tuner and its on a 03 suburban 1500 5.3
totally different issue if its an early GM, most likely some electronics interfering. is there an aftermarket radio or anything else wired into the truck?
