Cooling fans running at full speed after tuning
Robisonjon2891
I have a Silverado 6.2 and if I install the Diablo tune after one or 2 uses my cooling fans will start running at full speed and will not stop u til about 2 minutes after I turn the engine off or put the factory tune back on. Has anyone else had this happen to them.
Re: Cooling fans running at full speed after tuning
never heard of this. please load the tune and post the files from the tunes folder here so we can check it out.
Robisonjon2891
do you mean load the diablo tune on the truck then copy the files and post them here
yes please
Robisonjon2891
I did the diablo tune with the 4 cylinder mode off the speed limiter off 20% throttle boost also
the attachment files should be here also
the only fan related change in this tune is where we upped the target fan speed up to 30% of total power in the lower temp cells.
tuned: stock: Load this, it has the fan changes undone from the tune, and let us know if that resolves the issue.
