Speed Limiter U7131
Speed Limiter U7131
Just joined and searched and searched the forums for this subject but could not find and answer. Did the speed limiter option get removed with the update from 9r01 to 9r03?
rev 9r01
* Internal update
* Speed limiter adjustment added
* attempt to fix idle surge in 35xxx calids
Currently using version 9r03.
rev 9r01
* Internal update
2006 Red 3500 4x4, auto, Diablo Predator, 2in leveling kit, 305X75RX17 on Akuza Rims.
RE: Speed Limiter U7131
No, that just means it was added in 9r01...
Can you explain where I can find it to be able to adjust my speed limiter? Looked all through my predator but can not find it.
So, when you select modify tune, then modify parameters, you dont see speed limiter?
somethings up with ur predator?
I've got mine set at 121mph but it defuels at 3450rmp so it only lets me go 116mph
maybe once i get valve springs i can get a custom tune with 4k rpm.....mike
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
I'd say give us a call with the tool powered up so we can figure this out....
antisocial
What revision is on the Predator?antisocial wrote:Hi everyone! We have the same problem with the speed limiter. I've got mine set at 135mph and only lets me go 116mph. There is any change to have more speed?
