Speed Limiter U7131
Red3500
Speed Limiter U7131
Post by Red3500 »
Just joined and searched and searched the forums for this subject but could not find and answer. Did the speed limiter option get removed with the update from 9r01 to 9r03?
rev 9r01
* Internal update
* Speed limiter adjustment added
* attempt to fix idle surge in 35xxx calids
Currently using version 9r03.
2006 Red 3500 4x4, auto, Diablo Predator, 2in leveling kit, 305X75RX17 on Akuza Rims.
RE: Speed Limiter U7131
No, that just means it was added in 9r01...
Red3500
Post by Red3500 »
Can you explain where I can find it to be able to adjust my speed limiter? Looked all through my predator but can not find it.
kw5.9
Post by kw5.9 »
it's in the modify tune section you can also adjust the tire size there, hope you like the tool been love n mine for 2yrs!
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
Red3500
Post by Red3500 »
I checked under that location and the only thing there is the Idle Up and Tire Re size function. Am I missing something?
So, when you select modify tune, then modify parameters, you dont see speed limiter?
Red3500
Post by Red3500 »
Correct.
kw5.9
Post by kw5.9 »
somethings up with ur predator? :shock: I've got mine set at 121mph but it defuels at 3450rmp so it only lets me go 116mph :cry: maybe once i get valve springs i can get a custom tune with 4k rpm.....mike 8)
Red3500
Post by Red3500 »
Hmmmmm! Mike, any help here?
Red3500
Post by Red3500 »
Anyone find out what I can do to get this function added to my programmer?
I'd say give us a call with the tool powered up so we can figure this out....
Red3500
Post by Red3500 »
Will do. Thanks.
Red3500
Post by Red3500 »
Thanks everyone. Got it figured out after I called Tech Support. I was going into the wrong Modify Tune area.
antisocial
Post by antisocial »
Hi everyone! We have the same problem with the speed limiter. I've got mine set at 135mph and only lets me go 116mph. There is any change to have more speed?
ram 2500 5.9L 4x4 predator u 7131 v.9r04 from argentina buenos aires.
antisocial wrote:Hi everyone! We have the same problem with the speed limiter. I've got mine set at 135mph and only lets me go 116mph. There is any change to have more speed?
What revision is on the Predator?
