No worky code 68061222aa
aboz3
Post by aboz3 »
U 7135 reviision r18 2009 Chrysler 300C 5.7 hemi
Just received the unit was going to the strip tomorrow night directly after work...hooked up unit and it told me it does not support 68061222aa. WTH???? Uploaded latest revision....no luck...this is BS
RE: No worky code 68061222aa
There is an update posted here for the past several days to add support for your car.
It is in the stickies.
I see you posted about this twice, fwiw, had you searched it real quick, you'd have found the answer without any need to post.
Mike
aboz3
Post by aboz3 »
I down loaded your latest version 19g and it still won't work. What should I do next?
what happened?
what was the exact message it gave you?
aboz3
Post by aboz3 »
Thanks for the quick response. I believe that it said I 68061222aa needs updated, but I cannot remember for sure. I am at work, and have the info at home, so I will have to send exact message tonight. I got the car to run 14.008 of Friday night with only cold air and driving technique, so can wait to change the tune.
SeaBass67
Post by SeaBass67 »
Go to your dealer and have them reflash your car with 68061222AB. Takes minutes. Then you'll be golden :D
Re: RE: No worky code 68061222aa
aboz3 wrote:Thanks for the quick response. I believe that it said I 68061222aa needs updated, but I cannot remember for sure. I am at work, and have the info at home, so I will have to send exact message tonight. I got the car to run 14.008 of Friday night with only cold air and driving technique, so can wait to change the tune.
This can be updated using the dsdownloader through our website.
aboz3
RE: Re: RE: No worky code 68061222aa
Post by aboz3 »
So, I can flash 68061224AB and get the info on the dsdownloader? Are there instructions to be found on how to do this? Sorry about the ignorance, but I am just getting into the loop on modifying the new computer cars.
fordomatic69
Post by fordomatic69 »
Follow these instructions to the letter:
http://www.diablosport.com/index.php?mo ... ay&pid=117
You'll need the power supply and usb-serial cable as well.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
SeaBass67
Re: RE: Re: RE: No worky code 68061222aa
Post by SeaBass67 »
aboz3 wrote:So, I can flash 68061224AB and get the info on the dsdownloader? Are there instructions to be found on how to do this? Sorry about the ignorance, but I am just getting into the loop on modifying the new computer cars.
68061222AB
aboz3
RE: Re: RE: Re: RE: No worky code 68061222aa
Post by aboz3 »
Thanks seabass..I punched in the wrong number. All of the above worked and I installed the 93 cai tune. Took the car out for initial drive an it seems to surge while cruising 25 - 50 MPH. Will it take a fw cycles to smooth out?
concoursd
Post by concoursd »
do you have MDS still enabled?
aboz3
Post by aboz3 »
Yes, the MDS is still enabled.
Quick
Re: RE: Re: RE: Re: RE: No worky code 68061222aa
Post by Quick »
aboz3 wrote:Yes, the MDS is still enabled.
Then no, it won't smooth out in a couple of cycles :). Disable MDS
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
SeaBass67
Post by SeaBass67 »
+1 on disabling the MDS. Go with the 91 tune if you get knock.
