New trinity - Issues
General Trinity Support
baraz
Post by baraz »
I just received my new t1000, immediately had two problems:
1 - USB drivers do not work on my Vista, apparently is a language issue, the operating system is in italian and the drivers from the cd (or from the website) refuse to install
2 - Plugged the trinity to my 06 charger R/T daytona, tried logging using one of the redefined layouts and it won't display KNK, LT KNK
is there a fix for this?
Alex
RE: New trinity - Issues
doh!!! nah, they don't make foreign language versions...
you'll have to switch your language setting to English...
also, you have to make sure you're installing the software as the Administrator... if you/your account is not the administrator account and/or doesn't have administrator priveledges, then the stuff won't install either..
baraz
Post by baraz »
ok, I sorted the driver issue out, registered the T1000 and updated with the last rom But the other problem still remains, sometimes the monitoring shows no data and logging does not work. I get an error message saying cannot start the live stream or something like that
gizmodo
Post by gizmodo »
Take a picture of the end of the cable that plugs into the Trinity and post it here. Also, make sure the cable is seated. You have to apply quite a bit of force.
gizmodo wrote:Take a picture of the end of the cable that plugs into the Trinity and post it here. Also, make sure the cable is seated. You have to apply quite a bit of force.
Yes, please do this.
baraz
Post by baraz »
well, the connector is all the way in, sometime works, sometime I get the "cannot start the stream....bla bla" error message, retrying 2 or 3 times will eventually start the logging.
now, new issue: using one of the predefined layout (HEMI 05-06) the KNK St Retard, KNK Total retard and KNK LT Retard do not receive any data
baraz
Post by baraz »
I logged a couple of times adding some extra PID to the standard Hemi 05-06, this is what I got...
logs.rar
(397.55 KiB) Downloaded 636 times
gizmodo
Post by gizmodo »
That's the reason we are asking for a picture of the connector. It may seem as though it is seated but it is not. There is also a chance you have an old version of the cable with a connector that doesn't work very well. Please just post the picture.
baraz
Post by baraz »
here are the pictures....
OK, thats the new cable....does it seat properly in the Trinity?
baraz
Post by baraz »
yes it does, the connector is firm and all way in.....
gizmodo
Post by gizmodo »
If you tug lightly on it, does it come out? Mike had a way of putting the connector in that worked pretty well. I think he said put the left side in first, and then rock the right side in, but I don't remember.
baraz
Post by baraz »
yes, it comes out, from the left side, if i remember correctly.. I seem to remember the Knock sensors used to work on my predator, I don't see whyy they do not work now...
Thats the problem...hold the unit upside down and click it in all the way.
baraz
Post by baraz »
Tried turning the unit upside down, sideways, tried moving the connector when plugged in, no difference....
Now I'm puzzled, I tried the predator, watch and record, ST and LT... No info!!! Why is that? Something wrong with the car??
Return to “General Trinity”
