New trinity - Issues
I just received my new t1000, immediately had two problems:
1 - USB drivers do not work on my Vista, apparently is a language issue, the operating system is in italian and the drivers from the cd (or from the website) refuse to install
2 - Plugged the trinity to my 06 charger R/T daytona, tried logging using one of the redefined layouts and it won't display KNK, LT KNK
is there a fix for this?
Alex
Alex
RE: New trinity - Issues
doh!!! nah, they don't make foreign language versions...
you'll have to switch your language setting to English...
also, you have to make sure you're installing the software as the Administrator... if you/your account is not the administrator account and/or doesn't have administrator priveledges, then the stuff won't install either..
Take a picture of the end of the cable that plugs into the Trinity and post it here. Also, make sure the cable is seated. You have to apply quite a bit of force.
Yes, please do this.gizmodo wrote:Take a picture of the end of the cable that plugs into the Trinity and post it here. Also, make sure the cable is seated. You have to apply quite a bit of force.
well, the connector is all the way in, sometime works, sometime I get the "cannot start the stream....bla bla" error message, retrying 2 or 3 times will eventually start the logging.
now, new issue: using one of the predefined layout (HEMI 05-06) the KNK St Retard, KNK Total retard and KNK LT Retard do not receive any data
That's the reason we are asking for a picture of the connector. It may seem as though it is seated but it is not. There is also a chance you have an old version of the cable with a connector that doesn't work very well. Please just post the picture.
OK, thats the new cable....does it seat properly in the Trinity?
If you tug lightly on it, does it come out? Mike had a way of putting the connector in that worked pretty well. I think he said put the left side in first, and then rock the right side in, but I don't remember.
Thats the problem...hold the unit upside down and click it in all the way.
