Logs download as .txt files?
RockyRotella
Post by RockyRotella »
When trying to view other's posted logs, they open as .txt files when downloaded. How do I download/save them so I can view them with dv3.3?
jimb
RE: Logs download as .txt files?
Post by jimb »
When saving posted logs; may need to change the filename extension to *.LOG. Also, put them in "My Documents\Dataviewer\logs" folder.
gizmodo
Post by gizmodo »
Your computer is setup to open .log files with notepad. You can either change the file association of a .log file to DataViewer, or just go to DataViewer and open the log that way.
RockyRotella
Thanks for the info. I tried doing that and while some work suitably, others are "corrupt files." It must be something with older log files that were posted some time ago.
Re: RE: Logs download as .txt files?
RockyRotella wrote:Thanks for the info. I tried doing that and while some work suitably, others are "corrupt files." It must be something with older log files that were posted some time ago.
Yeah, older logs got messed up by the forum at some point. Anything posted recently should work.
Return to “DataViewer/DV2”
