Logs download as .txt files?
RockyRotella
When trying to view other's posted logs, they open as .txt files when downloaded. How do I download/save them so I can view them with dv3.3?
RE: Logs download as .txt files?
When saving posted logs; may need to change the filename extension to *.LOG. Also, put them in "My Documents\Dataviewer\logs" folder.
Your computer is setup to open .log files with notepad. You can either change the file association of a .log file to DataViewer, or just go to DataViewer and open the log that way.
RockyRotella
Thanks for the info. I tried doing that and while some work suitably, others are "corrupt files." It must be something with older log files that were posted some time ago.
Re: RE: Logs download as .txt files?
Yeah, older logs got messed up by the forum at some point. Anything posted recently should work.RockyRotella wrote:Thanks for the info. I tried doing that and while some work suitably, others are "corrupt files." It must be something with older log files that were posted some time ago.
