I just made my first log. as far as i can tell everything is fine, but is there things I can do to improve it?
I have an afr gauge and they stayed at 12 untill the very end and droped to 11.9
stg 1, stock turbo, cai, bfmic, basic bolt ons
https://www.yousendit.com/download/Z01P ... WS92Wmc9PQ
I also have been unable to change the red line and the temp on/off for the fans.
shold I tune with the e-cut out open?
this is a log of 1st and 2nd gear where if found out the revlimit did not change
https://www.yousendit.com/download/Z01P ... RTgwTVE9PQ
thanks
7134 9r18 srt-4 log
7134 9r18 srt-4 log
04 SRT-4.AGPwastgate,motor&trans mount,DCR top end modifer,255Wallbo W/rewire,60mm tb,UDP,Needswings dp E-cutout, MagnaFlow exhaust,bfmic,8.5MSD wires, Granatelli coil,5107 NGK plugs, N2MB wot box, AGP Delya 48,DW 1300 inj.,Bosch 044 pump,E-85 and of course a DSP.
try this log
ok try this. I think I got it this time.
- Shortcut to 3rd gear.zip
- 3rd gear
- (618 Bytes) Downloaded 83 times
- Shortcut to 1st and 2nd gear pull.zip
- 1st and 2nd
- (664 Bytes) Downloaded 87 times
RE: try this log
The 2 zips are no good. The .cvs isn't much use but the 1-2 gear link worked.
Notes:
1) LTFT is pulling a little fuel. flashing a tune doesn't clear it so disconnect the battery.
2) AGP wga is weak compared to a well tuned stock wga. its 1-2psi low at 6000. think about it using a stock wga
3) there a bit of knock but I'd get more seat time on the tune to see if its consistant or random. Clearing the -2% LTFT might help a bit.
Notes:
tune
did I do these right?
- orginal back up.drg
- (64.03 KiB) Downloaded 68 times
RE: tune
I mistyped on that last post.
The .csv file ISN'T of much use. ".log" file is what's needed.
original back-up file isn't of much use either without the performance tune's "last tune written". The file you posted is just the stock S1 tune
