9R07 U7151
JohnD_LHP
9R07 U7151
Post by JohnD_LHP »
I have 2007 F-150 Harley edition. 9R05 sucked!! 9R06 would not load! 9R07 will not load either. Getting a little frustrated!!! Please help.
RE: 9R07 U7151
What is the error you get when you try to load 9r06 or 9r07?
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
cannot put last tune. restore original back up
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
i spoke with Vas last week, he was aware of the problem and assured me that 9R07 release was taking care of it.
RE: 9R07 U7151
I am confused...you say you cant load 9r07 but it is supposed to be the fix....so, does 9r07 load?
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
No. both versions update the device with no problem. however i cannot get the device to install either tune, 9R06 or 9R07. both versions get stuck in a loop. cannot put last tune - restore original backup. Vas conifirmed others are having the same issues with 9R06 and that 9R07 would be the fix. well it has not fixed anything. same error on both latest versions.
kmac1
RE: 9R07 U7151
Post by kmac1 »
Did you restore the original backup before you updated it everytime? What tune is in the truck right now? stock? Does the truck still run?
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
yes, i restored the original backup prior to each update. the truck runs fine. i have the stock program installed.
kmac1
RE: 9R07 U7151
Post by kmac1 »
what is your calibration ID? I would like to test this in-house.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
where is the cal-id located?
JohnD_LHP
RE: 9R07 U7151
Post by JohnD_LHP »
ok i located the calid # RXDE4D6. the tool is stuck in a loop trying to restore the original tune. Please help me reset the tool. it is useless at this time.
RE: 9R07 U7151
Give us a call with the tool powered up and we will reset it and then you can use 9r05 for the meantime.
atrain
RE: 9R07 U7151
Post by atrain »
I am having the same problems. 2007 f 150 4.6L. It says it cannot install 9r07, then it says that it cannot install the original backup. the truck seems to be running okay though. I am just as frustrated, i bought it 3 months ago and have yet to be able to use it.
tinslwc
RE: 9R07 U7151
Post by tinslwc »
This sounds very familiar. I have not put 9r07 on my predator yet to try it but 9r06 put me in the endless loop. It loaded perfectly to the tool and never wrote anything to the truck (but did lock itself to the truck). Right now, I have the stock tune loaded (from the prep to go from 9r05 to 9r06. I am pretty frustrated also. I bought the thing just to fix my speedo for larger tires (and 9r05 wont do that) and 9r06 wont do anything. I guess I will try 9r07 tomorrow and see where I get. Fortunatly, I am still within my 30 days so if its not straightned out, I can still send it back.
2008 F150 5.4
kmac1
RE: 9R07 U7151
Post by kmac1 »
Ok guys, I have finally duplicated this issue on our in-house truck. We are working like mad to fix it and we will post up the fix ASAP so keep checking the the downloads page for the next update.
Thank you for your patience!
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
Return to “Predator Ford Gas”
