I have a predator for my 06 6.0 psd. I went to the diagnostics and got a cal ID that I swear says AMZ2AL12. Can this be right. The sticker on the back says 2005 6.0. The boot up has predator and v.7r84. I got a vxcf1d6.hex as well. Some more info off the unit is ser# 20010d9. Load 1009282455.
Power 6.0-784-h512 11/04/2005 03:48:30 pm. Is the Cal ID correct or do I need to try again? If the ID is correct, then, I think that this is still running a program from Nov of 2005 (if I am understanding what I see). I want to update this because I suspect there has been much advancement over time. Please give any advice freely. I will be responsible for any advice I accept. Thanks and again, please tell me if this is a valid CAL ID. thanks rc
predator with a cal id AMZ2AL12?
RE: predator with a cal id AMZ2AL12?
You need to update your Predator to the 8r10 and then the 8r17 revision.
This will allow it to work with your calid.
thanks, that's what I'll do. rc
