.035a after 10min or so.Quick wrote:Quantitative question: Since some modules take some time to power down I would expect there may be a few current draw numbers for diagnostics? Like max current draw immediately after key off and then a lower max current draw after some amount of time? Is 0.035amps what you would expect immediately after key off? or after 10 or so minutes?
I checked the 06 service manual and it says you need to wait only 3 mintues. It also has a breakdown of all the accecories and how much amperage they draw with the key off. A quick sum puts it only at .010a.
It would be cuirous to see if the 09 manual is different.
