TAHOE LT 2010
redfoxsa
TAHOE LT 2010
Post by redfoxsa »
Hi Folks
CAN i USE a Trinity with my 2010 TAHOE
and What kind of tune can be done with the T-1000
- Can i reset the shifting point for Six-Speed Transmission
Regards
RE: TAHOE LT 2010
yes, you can use the trinity on that...
you'll have a Diablo Tune (for 91/93 octane gas), and an 87 octane tune...
no, you can not change any tranny parameters yet...
you CAN adjust:
COT time delay
DoD disable
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-4.9k / 5k-7k
Rev Limit
WOT Spark (in degrees) 1k-3.8k / 4k-5k / 5.2k-7k
Fan adjustment, individual adjustment per temp dependent cell
Tire Size
Speed limit(truck/SUV only)
Read/Write time is approx 60 seconds
Clear codes supported
Live data and log supported
Holds up to 5 custom tunes & Dat viewer is supported.
redfoxsa
RE: TAHOE LT 2010
Post by redfoxsa »
- someone told me that i have to reprogram my car after i install the Exhaust cat-back ,
can i use the Trinity to do that and how , ( i have a magnaflow on my Tahoe )
also , if i add a ( volant ) cold air intake ... Do i have to reprogram or there is a special setting to get a maximum result ?
Thanks in advance
RE: TAHOE LT 2010
do some data logging and get your fueling adjusted...
redfoxsa
Re: RE: TAHOE LT 2010
Post by redfoxsa »
06MonteSS wrote:do some data logging and get your fueling adjusted...
Thanks For Replay
i will waiting for my Trinity then i will back to you
Regards
redfoxsa
RE: Re: RE: TAHOE LT 2010
Post by redfoxsa »
in my country they have a 91 and 95 octane fuel ,what should i use in the tuner ?
95 octane gas in the truck...
diablo tune in the trinity...
redfoxsa
2010 List
Post by redfoxsa »
i install :
trinity_u7194-1r07a_update.crom
To my Trinity
but the only vehicle appear on Chevrolet 2010 is Camaro !!
How can i found my Car
RE: 2010 List
select 2009 tahoe....
it's the same truck, same tunes, etc etc
redfoxsa
RE: 2010 List
Post by redfoxsa »
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM9 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6JSYXXX-1'.
Part number = 'u7194'.
CROM version = 'u7194-1r07a 02/18/2010 02:45:28 PM boot3'.
Vehicle VIN = '1GNUKBE0XAR100000'.
Vehicle Calibration = '12636005'.
Origional backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Config does NOT indicate multiple ECUs.
Tool reports 1 ECUs.
redfoxsa
RE: 2010 List
Post by redfoxsa »
Even With : trinity_u7194-1r07a_update.crom
i found Tahoe 2009 but i can not do any performance program or tune ??!
Return to “Trinity GM Gas”
