LTFT
randall
LTFT
Post by randall »
I got the LTFT set in the 2000 rpm range to run -2 to 0 which is about 55 mph. When im on the Hwy. running 70 around 2400 rpm LTFT are at -4 to -6. What should be done to make this more consistent. u7193 2.03version, 240sx with engine swap, 04 gto 4l60e, ram air, ported throttle body, long tubes, 2.5 duals with xpipe no cats.
Speeddemon
RE: LTFT
Post by Speeddemon »
Wow, nice car dude. I think the reason for the change in LTFTs are due to the fact that your running at a higher RPM.
"The Speed Demon"
RE: LTFT
yep... ^ ^ ^ ^
wow, high rpms at a 70mph cruise... is that what you normally cruise at, 65-70mph? cruise at your normal speed/rpm, and adjust the stuff based on that scenario...
randall
RE: LTFT
Post by randall »
Thanks, Yah thats with a 3.54 diff. and 235 45 17 tires. The stock gear was 4.08 that i swaped out before i got the engine done. I know it would have be way low for the auto. I may swap it out some time and take it to the track.
Speeddemon
RE: LTFT
You may want to see about changing to a 4L80E trans, if I'm not mistaken the 4L60E is a five speed auto and the 4L80E is a six speed auto. The extra gear helps with highway cruising.
"The Speed Demon"
jrmybck
RE: LTFT
Post by jrmybck »
my ltft raise on the gas. they deffinately dont go - what do i need to do. they are 0.00 at idle and go clear up to 5.00 on the gas
RE: LTFT
when you're driving steady on the highway, what are they reading???
jrmybck
RE: LTFT
Post by jrmybck »
havnt been on a highway. i will try it asap
RE: LTFT
yeah, have to be on the highway, driving at steady throttle... rpms 1800-2200...
and see what they're at...
Return to “Predator GM Gas”
