Error Validating File ?
eortiz
Post by eortiz »
Yes Diablo website under the download tab = easy instructions - 15 minutes tops on your computer another 15 on your car .
eortiz
Post by eortiz »
Opps sorry on the top line you wll see Support - click on that then you will see downloads -
DennyD
Post by DennyD »
I just recieved my replacement Predator. Its V.20 and it works. So the problem is with the v.23. They haven't figured
that out yet since they just tell you to order another one. I was able to load the "modify parameters" but i have yet
to test the fans coming on at the lower temps of 195 and 185 degrees. Also i set the rev limits to 6600 and the trans
shft point to 6600 but its still shifting at 6200 at WOT. I have a CAI , Jet 180 stat, and also I'm installing an undersize
pulley from SLP later this month. So far I've noticed a slight increase in "pep"but not enough to warrant the expense
of tie Predator. Maybe you need more mods to make it price effective.
DennyD wrote:I just recieved my replacement Predator. Its V.20 and it works. So the problem is with the v.23. They haven't figured
What vehicle do you have?
Sure you have good fuel in the tank?
magnitude
Post by magnitude »
eortiz wrote:Ok - Now I know I'm not going crazy or feeling really stupid -
DennyD and Skinytall
Commons here are:
all 06's
Revision 9R23
all have calid 05030232AE
Can't adjust any thing with modified tunes -
Error Validating problem message pops up.
Let me share what I did to make it work:
I downloaded Revision 9R12 which is a older version - 9R23 doesn't do nothing for 06's if I'm correct.
I worked like magic - Version 9R23 doesn't communicate with my PCM.
This is what I'm concerned about. Just bought a Pred (for my 06 Mag R/T) with 9r23 pre-installed and wondered if 9r12 would work better. I'll make the crom change.
eortiz
Post by eortiz »
My problem is with ver. 9R23 I couldn't adjust any Modfiy parameters. For some reason with 9R12 I could and I had 2 diffrent Prediators doing the same thing. I have an 06 SRT8 Charger. It's running good with modified paameters.My concern is that I can't update along with others as new revisions are released.
eortiz wrote:My problem is with ver. 9R23 I couldn't adjust any Modfiy parameters. For some reason with 9R12 I could and I had 2 diffrent Prediators doing the same thing. I have an 06 SRT8 Charger. It's running good with modified paameters.My concern is that I can't update along with others as new revisions are released.
9r12 is all oyu'll ever need for 05-08 vehicles.
eortiz
Post by eortiz »
Wow! that's sad to hear.
Ok than I'm all good - thank you for all your assistence.
Ed
DennyD
Post by DennyD »
MIKE,
In reply to your question:
I have 06 Magnum srt8. Additional question. Where in Amazon.com can I order a "catch can"
I see you have it for sale on your website but I like working with amazon..." no questions asked for returns" ....policy.
If they don't sell it for you then i'll have to purchase it from your website. Usually Amazon has a better price on things.
thank you
denny
eortiz
Post by eortiz »
Maryland Speed.com is an awesome speed shop supplier. Very reasonable pricing.
jinksnyou
Predator ver 9r23
Post by jinksnyou »
Has any thing been fixed about this problem with the 06's?
eortiz
RE: Predator ver 9r23
Post by eortiz »
According to DS version 9R12 is all we need for 06 - 08. As far as why it doesn't validate if you buy a prediator with the Ver.9R23 on it - No not yet - you will have to downgrade your pred to the 12 version. I'm not no engineer but perhapas a software conflict.
magnitude
Post by magnitude »
Anyway to get 9r08 crom since that seems to be last relevant firmware for 06's?
eortiz
Post by eortiz »
Ds is best fit to answer that question but version 12 works just awesome?
SRT8waggin
Post by SRT8waggin »
Great! i just got mine and its doing the same thing. Now I've got to spend more money? Can I just send this back?
