CROM u7135-v.9r23 Incompatible hardware. (No serial flash...
hdmichigan
Post by hdmichigan »
Trying to load CROM v.9r23 onto my used U7135; takes v.9r12, but I need more recent version for my
2010 Jeep Grand Cherokee SRT8
Screen reads "Incompatible hardware. (No serial flash found).
While used, I bought this Predator from another enthusiast after confirming on the Diablosport website that the U7135 had a CROM update that includes the 2010 Jeep GC SRT8 (no mention on the website that there might be hardware limitations). Thanks.
RE: CROM u7135-v.9r23 Incompatible hardware. (No serial flas
email sent
Re: CROM u7135-v.9r23 Incompatible hardware. (No serial flas
hdmichigan wrote: (no mention on the website that there might be hardware limitations).
From the U7135 downloads page on this site:
If you attempt to update your Predator to the latest crom and it gives you a serial flash error message you will need to go back to 9r12.
If you are trying to update the Predator for use on an 09 vehicle, please post up on our forums or give us a call and we will get you a crom file for the older Predator to make it work with the 09.
hdmichigan
RE: Re: CROM u7135-v.9r23 Incompatible hardware. (No serial
Thanks for the file, Mike, and the rapid response.
bobsmyuncle
Same Problem
Post by bobsmyuncle »
181524
v.9r12
2005 Dodge Magnum RT
I'm getting the same message, can you advise me what to do?
stevenm002
RE: Same Problem
Post by stevenm002 »
I'am getting the same problem i can not downgrade to u7135-9r12.crom from u7135-v.9r17
incompatible hardware (no serial flash found)
contact tech support
CAN YOU HELP ME PLEASE
Steve
Re: Same Problem
bobsmyuncle wrote:181524
v.9r12
for an 05, stay with 9r12.
Re: RE: Same Problem
stevenm002 wrote:I'am getting the same problem i can not downgrade to u7135-9r12.crom from u7135-v.9r17
Steve
You are trying to go from 9r17 to 9r12??
bobsmyuncle
RE: Re: RE: Same Problem
Thanks for your help, took me a while to figure how to do that though. For others searching after opening DS Tuner choose the "corupt..." option, follow the instructions from there....
Out of curiousity, does this mean that I miss out on 'improvements' that came after this version?
Return to “General Support”
