Hi Mike,
Can you get me 87 Tune & Performance Tune maps to use with Long Tubes for U1792 & Hummer H2? I'd really appreciate it if you would email them to me at [email protected]
Please let me know how to get these into the tuner? Which cable I need, sofware or instructions etc. Thanks Mike!!!
Mike, need map for U1792 & Hummer H2
RE: Mike, need map for U1792 & Hummer H2
I'll need a copy of your backup file first.
I am emailing you the instructions.
Thanks Mike, I got your email. One question though, the file you are asking for - is this the original OEM file or a backup of my current modified file I loaded into the ECM using the tuner?
Copy of the backup file from the Predator. (OEM tune)
Hi Mike, finally found the serial cable and power adapter to get this file uploaded to PC. I am replying to you email with a copy of my backup file. Thanks Mike!!!!!!!!!!
Tunes have been sent already.
Wow, that was quick! Thx Mike!
Quick question though...I just read the darn doc you sent to download the file to PC. It seemed so easy that I didn't bother to read it until now. Question is, in Section that says "Note: Before uploading the tune to PC the following step must be performed", what is this step actaully doing? I didn't do this step, prior to sending you my OEM file, but this does not sound like something I needed to do. Am I correct in my assumption here?
Mike, also please help me understand something: why are the changes you make done to the OEM file and not one of the Diablo files? Just curious and want to udnerstand, thanks
