M2000
1999 Damon ultrasport 36.5' motorhome
1998 CAT 3126 diesel
Installed puck and engine won't start. If I take out only the ICP wiring harness connectors and reinstall the originals it starts fine.
The wire colors match the instructions for the ICP and the MAP so I have in correctly. I have a CAT troubleshooting manual and it shows the ICP sensor also.
I am using the connectors on the end of the new wire harness for the ICP. Doesn't say inthe instructions which connectors go on which sensor. If you have more info on the 3126 please send that also.
If I can't get get this working do I return it to you or where I bought it (Throughbred Diesel).
Won't start
RE: Won
[quote="pluckyman"]M2000
1999 Damon ultrasport 36.5I have done some troubleshooting and I think the problem is in the puck. I'm adding some pics of where I connected the puck and also a schematic of how my harness is wired. Let me know if all is correct of not.
- ICP sensor 2.jpg (60.75 KiB) Viewed 7977 times
- MAP sensor 2.jpg (62.11 KiB) Viewed 7977 times
- (385.06 KiB) Downloaded 439 times
RE: Won
[quote="pluckyman"][quote="pluckyman"]M2000
1999 Damon ultrasport 36.5I have done some troubleshooting and I think the problem is in the puck. IThe schematic didn't take so I'm trying again.
- Wire Harness.jpg (133.79 KiB) Viewed 7974 times
