It is the same tune you posted with the TM deleted.Jesse_01 wrote:so that tune you adjusted. What all did you do to it? Also was that with the previous timing adjustments made to it? Or is it the standard performance tune with your adjustments you made?
Advanced Trans Tunning 2010 Ram 1500
Okay. Would I be able to post up the 93 tune with stock diablo parameters and get you to TM delete that. Just so I have a clean sheet to tweak things with.
On my tune when I loaded it, everything showed as unmodified. So I don`t really have an idea of what was adjusted and how much.
Also is the tm 100% deleted or a certain percent?
I also mentioned on a forum how helpful and quick with response you are. So there may be a few people asking around for the same thing
Jesse
Jesse
No prob, write the unmodified tune, export it, and post it here, and we'll tweak that for you.
I have no problem offering these tunes to anyone who is interested, especially if we get some feedback on them.
I just updated my tuner and seen there is a 91 octane tune. So here is my last tune written unmodified.
Jesse
Jesse
- Jesse_Perf_91oct.drg
- (4.25 KiB) Downloaded 175 times
here you goJesse_01 wrote:I just updated my tuner and seen there is a 91 octane tune. So here is my last tune written unmodified.
Jesse
- jesse_perf_91oct_001.drg
- (73.9 KiB) Downloaded 164 times
What would you need from me to get me a TM deleted 87 and 93 octane tunes? I have a Trinity t-1000 on my 09 hemi ram. SuperChips adjusts the TM on the transmission side. Are you guys adjusting it on the engine or transmission side? I know that if I stall up at the line at the drag strip it kicks in tons of TM even with the 87 and 93 tune and causes it to take off like a dog. I can't stand that. Hook me up Mike! My truck is the test mule for Vararams new Hemi intake and even Patrick(Vararam owner developer) stated how bad the truck is holding back when taking off and shifting.
Jerimie
Jerimie
i was planning on selling my predator until i saw this thread, if theres antyhing you can do to help these hemis off the line with a custom tune or something. i have been runnning the 93 tune since day 1 with a simple volant intake,magnaflow muffler and a 180tstat. it does feel better than stock top end wisebut the bottom end off the line is slow.
Can we please get in on some of this TQ Management reduction removal please? It's even worse now that I have my 4.56's installed and WOT shifts set at 5900rpm with a 6200 rev limiter. It shifts like a amateur on a manual transmission. It literally nose dives(pauses) under a WOT 1-2 and 2-3 shift and that is eating valuable time in a 1/4 mile. Not to mention the horrible noise it makes when it throttles back(TM) at 5900rpm. It makes a loud gurgle or something like that when it WOT shifts and causes a code P1004 to be thrown. I need this TQ Management gone.
Yeah, it helped a bit, but its still a dog on the take off. Than it hits about 4000rpm and takes off. Anything low rpm sucks with these trucks. I have 37's on now so its pain full. I kind of want to find a superchip for cheap so I can compare the two.. This truck supposes to make so much power yet its a dog on the bottom. Might have to buy a high stall torque to fix the bottom end, I dkn.
I miss my diesel lol.
