Thanks Lew! Nice complement..
Markus, Even after you find the culprit you will still have to do a idle re-learn or you will have the same symptoms for a number of starts afterwards, don`t be fooled. Follow this to assist you in correcting the problem.
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Reprinted on OBDII web site courtesy of General Motors Corporation
© General Motors Corporation
Corvette Mj 09 Z06 - Lean Code
- Ill_Born_SS
Post by Ill_Born_SS »
" Just Friggin Wicked"
Now with TCM support...
Jump to
- Welcome to DiabloSport
- ↳ Announcements
- ↳ Test Vehicles Wanted
- i2/i3 Technical discussion
- ↳ i2/i3 for Dodge, Chrysler, Jeep and Ram
- ↳ i2/i3 for Ford vehicles
- ↳ i2/i3 for GM vehicles
- ↳ Ignition updater
- Trinity 2
- ↳ T2 for Dodge/Chrysler/Jeep/Ram
- ↳ T2 for Ford
- ↳ T2 for GM
- ↳ Trinity MX monitor
- PredatorX
- ↳ PredatorX for GM vehicles
- ↳ PredatorX for Dodge/Ram vehicles
- ↳ PredatorX for Ford vehicles
- ↳ PredatorX Requests and Feedback
- Predator 2 Support
- ↳ Predator 2 for Chrysler/Dodge/Jeep/Ram
- ↳ Predator 2 for GM
- ↳ Predator 2 for Ford
- Pulsar
- ↳ Pulsar for Ram
- Trinity Technical Discussion
- ↳ General Trinity
- ↳ Trinity Ford Gas
- ↳ Trinity Ford Diesel
- ↳ Trinity Dodge Gas
- ↳ Trinity Dodge Diesel
- ↳ Trinity GM Gas
- ↳ Trinity GM Diesel
- inTune i-1000 Technical Discussion
- ↳ General inTune forum
- ↳ Auto Updater/PC related issues
- ↳ Mac/Non Windows based issues
- ↳ inTune DCX (i-1000-DCX)
- (Legacy) Predator Technical Discussion
- ↳ Predator Ford Gas
- ↳ Predator Ford Diesel
- ↳ Predator Dodge Gas
- ↳ Predator Dodge Diesel
- ↳ Predator GM Gas
- ↳ Predator GM Diesel
- General Technical Support
- ↳ DataViewer/DV2
- ↳ General Support
- ↳ Custom Tune Support
- ↳ DeltaChip
- ↳ MAF.i.a
- ↳ DSDL
- ↳ PowerPuck/Extreme PowerPuck
- ↳ CatchCan Support
- DiabloSport Community
- ↳ General Questions
- ↳ Lounge
- ↳ Suggestion Box
- ↳ Future Product Requests
