No high idle
No high idle
I was installing the performance tune and i wanted to modify it for tire size and high idle but they were not there? The only things i could adjust were rev and speed limits. I really need the high idle for winter if there is any update i can do it would be awesome!
RE: No high idle
what vehicle, tool, revision?
RE: No high idle
i'm sorry its an 03 ram 2500 with the 5.9 with the predator u7130 with i think the latest update.
03 cummins with pred off, straight pipe, afe, filters, Fass lift pump, and adjustable boost elbow.
RE: No high idle
don't think the high idle option works on the 7130 and for sure there is no tire size changing
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
RE: No high idle
I thought i read somewhere that you could adjust that... Well thats gay if there's not one my truck needs it in the winter.
RE: No high idle
pretty sure dealers can turn it on if its not on. Is yours an auto or manual. if its a manual then there is some other stuff to do to make it work. http://www.cumminsforum.com/forum/3rd-g ... -idle.html here is some info on it
Reg
RE: No high idle
yea i have a manual
RE: No high idle
I didn't read the link above, it probably contains the info you need. But you have to ground pin #22 in the rear pcm plug with a pigtail from cummins in order to use high idle. And then it has to be enabled either by a programmer (appearently not in your case) or by the dealer
