2005 mustang gt with air induction running lean
dp9849
Post by dp9849 »
Code: Select all
u7140
2005 ford mustang gt
j.mike@diablosport
RE: 2005 mustang gt with air induction running lean
Post by j.mike@diablosport »
We're really going to need a question to figure out what you need to know here.
What brand of cold air kit are you using?
Diablosport Sales Team
Caffeine Engineer
Please do no PM me! Send an email to [email protected] if you need to contact me.
dp9849
Post by dp9849 »
[quote="j.mike@diablosport"]Wei bought the mustang this way, the intake has AFE stamped onto it , getting code P2272 lean condition.
speedshop
Post by speedshop »
AFE claims no tune required, but I don't know if they have a reducer or not on the inside. I'll have to check there site. You could try adding 8% to the MAF transfer for now. Have you checked the fuel trims at all?
dp9849
Post by dp9849 »
i added the 8%, so now to drive her for a few days to see if light stays out, thanks. havent checked the fuel trims yet
j.mike@diablosport
A lean condition can also be due to an air leak. Check all the clamps and fittings on the intake system.
Caffeine Engineer
dp9849
Post by dp9849 »
light came back on same code, p2272, what else can cause this code?
dp9849
Post by dp9849 »
also replaced MAF sensor, checked fittings and intake for loose connections, still no luck, im at my wits end here, giving up and taking to a garage... thanks for your suggestions,
julan
Post by julan »
you need to check weather it is really lean by a wide band.
dp9849
Post by dp9849 »
whether its lean or not, the code is still there and i cannot get the car inspected. thanks for your heklp
try adding up to 15% to the MAF curve.
dp9849
Post by dp9849 »
ive been told i have a bad catitytic converter on the drivers side, i have to put on a new exhaust. so nothing else will help that , thanks for taking the time to help me out.
dp9849
Post by dp9849 »
i cant even spell "catalytic "right,,, hard code to troubleshoot,,, seems i got ripped off when i bought the car, on the left rear o2 sensor had a resistor to keep the cat code off, thats what was tripping the "lean code" drivers side cat on the x-pipe is bad and the system is welded. so when my wife comes home with my truck , we are getting a new exhaust system, and putting it in this weekend. magnaflow xpipe and pipes to the rear, nice sound and she will be legal as well
dp9849
Post by dp9849 »
so tomorrow i finish installiing a magnaflow xpipe with new cats, replace the fudged O2 sensor . Is there any special tuning tips i can do with the combo of AFE intake and the X-pipe, with a 5 speed.
dp9849
Post by dp9849 »
passed inspection today after replacing x pipe and removing resistors on the o2 sensors that hid a 'bad cat code' and turned the p2272 code on. so i was troubleshooting for a vacuum leak when i had a bad cat. now its running great with the 87 octane performance tune in except for hard starting 1st thing in the morning, any ideas for that???
Return to “Predator Ford Gas”
