Stock Tune with less TM 2010 Ram
Is it possible to have you take the same Torque Management from my stock vehicle tune as you remove from the 9r09 update. The 9r09 update seems to cause quite a bit of LT KR @ part throttle in my truck. I log the stock tune and get no ST or LT KR @ part throttle. I do quite a bit of towing so I dont want to take a chance with a 5K + lb travel trailer and any engine knock under a load up a hill. I am using the "modify stock tune" and have gotten set up the way I like it with know KR and advanced WOT spark. Any help and info will be appreciated, Thanx
If i was you id get rid of the tuner as lots of us with 09 have the same issues as your self and they havent done nothing to fixe the problems stock tune fine caned tuneds useless and they still have done fuck all look up post for part throttle knock and i wouldnt tow nothing on the canned tunes its been a joke dealing with them better off going with super chip no headeach. like lots of .
Can you post your last tune written?
Here is the last tune written, I would just like the TM reduced to the same as the 9r09 update @ WOT. Just looking for more pick up off the line @ WOT with out tearing up the tranny. Thanks Mike
- PCM_05187935AD_Modify_Stock_Tune.drg
- (1.25 KiB) Downloaded 119 times
here you go.
- pcm_05187935ad_modify_stock_tune_001.drg
- (74.11 KiB) Downloaded 119 times
