Stock Tune with less TM 2010 Ram
yzf856
Post by yzf856 »
Is it possible to have you take the same Torque Management from my stock vehicle tune as you remove from the 9r09 update. The 9r09 update seems to cause quite a bit of LT KR @ part throttle in my truck. I log the stock tune and get no ST or LT KR @ part throttle. I do quite a bit of towing so I dont want to take a chance with a 5K + lb travel trailer and any engine knock under a load up a hill. I am using the "modify stock tune" and have gotten set up the way I like it with know KR and advanced WOT spark. Any help and info will be appreciated, Thanx
rstp
Post by rstp »
If i was you id get rid of the tuner as lots of us with 09 have the same issues as your self and they havent done nothing to fixe the problems stock tune fine caned tuneds useless and they still have done fuck all look up post for part throttle knock and i wouldnt tow nothing on the canned tunes its been a joke dealing with them better off going with super chip no headeach. like lots of .
yzf856
Post by yzf856 »
bump
Can you post your last tune written?
yzf856
Post by yzf856 »
Here is the last tune written, I would just like the TM reduced to the same as the 9r09 update @ WOT. Just looking for more pick up off the line @ WOT with out tearing up the tranny. Thanks Mike
PCM_05187935AD_Modify_Stock_Tune.drg
(1.25 KiB) Downloaded 118 times
yzf856
Post by yzf856 »
Dont forget about me mike, thanks
here you go.
pcm_05187935ad_modify_stock_tune_001.drg
(74.11 KiB) Downloaded 119 times
Toyorider
Post by Toyorider »
Mikel,
Are there going to be any future updates to resolve the part throttle knock issues?
