New U7192 problem data logging
classic07
Post by classic07 »
I connected my Predator and tried to do a data log. I selected short and think I recorded about 5 km of cruising, filled about 7 percent of memory. I then disconnected the unit and took it inside to download to my laptop. I started up Dataviewer 3.3 and it cannot find a log. I manually went through the log menu and could not find my log data. So my question is what is the proper way to create a data log on my predator?
BTW, I have searched the forums and did not find anything to help. A full manual for 7192 would also be nice.
U7192
9r13
2007 Chevrolet Silverado classic 5.3
RE: New U7192 problem data logging
you need to press the ESC button if you want to stop/save the data log in the middle like that...
press the ESC button a few times until back at the main menu... or press the ESC button and respond to any prompts given on the screen...
classic07
Post by classic07 »
Thank you, that is working for me. Now I need to sift through the data and then run it through redux.
Predator U7192
2007 Silverado Classic Extended cab, long box 4x4, Z71 work truck
87 octane fuel with up to 10% ethenol (-2 fuel slope)
K& N Cold Air intake system
classic07
Post by classic07 »
So I have reviewed the data, ran it through redux, got a recommendation and customized the tune. Now I want to check WOT. I start the full logging function wait until I see data being recorded on the predator and take off hard and long then cruised a bit. I reviewed the data in excel and there are no readings for my WOT run, just the cruise part. Can the predator not record all the parameters during a WOT? Do I need to record only certain parameters for proper WOT data recording?
Predator U7192
Ill_Born_SS
Post by Ill_Born_SS »
" Just Friggin Wicked"
Now with TCM support...
Return to “General Support”
