Odd.
We have seen it turn the screen to lines when you plug it in, thus we recommend not doing that, but I have never seen one not be recognized.
Did you try to see if anything else can format the card?
SD card problem.....
RE: SD card problem.....
Your on 1r08 Correct?
Have Trinity powered off before inserting SD-Card (with Trinity facing up); have the 9 gold pins facing up and notch on left when inserting card. Then power Trinity up.
Select Options->SD Card Operations->Properties should show (appox 62000) Total clusters and 1G+ Bytes avail for a formatted 1GB SD-Card.
Is a 1Gb card max?
2004 DR QC, 5.7, CAI, 6.1 rods/springs, KRC 210 cam, Pacesetter LTs, x-pipe- no cats, dual DMH cutouts, 6.1 ignition conversion, Auburn LSD w/456 gears, e-fan, powerwire, Sonnax line boost, Trinity CMR 93 tuned, Innovate LC-1
2GB Class 4 cards are the max.
THX
RE: Re: RE: SD card problem.....
It's either your Trinity or the SDCard. Make sure it's less than 2GB and it "clicks" in place when inserting in Trinity.
IF you have a PC/Laptop or digital camera; Try the SDCard in that and see if it detects and formats it. Or, try another SDCard.
latvat
I have exact same problem with my trinity and 512MB SD card. I have also tried other cards but no success.
I just get the message "SD card not installed or detected"....
SRT8_in_CT
Re: RE: Re: RE: SD card problem.....
Did you get the SD card issue resolved Harrison?HarrisonZ wrote:It's not the card. I've got a 2GB and a 1GB. They both aren't recognized. Damn..... I was hoping it wasn't the Trinity. They both format as a .FAT just fine in my laptop. Arrrgh.... I can't drive my truck without a Trinity b/c we turbocharged it. I was hoping this wasn't the issue. Oh well, guess no SD Card option for me.
Ken
skidmark70
RE: Re: RE: Re: RE: SD card problem.....
Mine is doing the same, plug card in and wont power up, removed card and powers up. tried 2 gb, and 1 gb. will try to format to FAT on the laptop and try again. is there anything that can be done if i send unit back to Diablo?
mulisha911
How to video: DiabloSport Trinity
Tutorial - How to install tunes onto your SD Card
The link: http://www.youtube.com/watch?v=e8kqDWgvCm4
