Hey fellas i just got the newest crom in. u7137-r911. In the parameters throttle sensitivity was replaced with 'throttle boost' is there a difference? or is it just the word?
Thanks for your help
Throttle boost or sensitivity? 07 ram
RE: Throttle boost or sensitivity? 07 ram
same param, new name
Why would you change to the term "throttle boost"?????? Doesn't make any sense!
it boosts the throttle....
silverdaytona
So what is added or improved on 9 revision 11 that was not on 9 revision 10?
Re: RE: Throttle boost or sensitivity? 07 ram
Sounds like an uninformed computer geek vs. a gear heads description to me.mikel wrote:it boosts the throttle....
RE: Re: RE: Throttle boost or sensitivity? 07 ram
If you look, there is a good reason for the use of the term 'booster', as there is another company making a killing on a device by that name
Also, you and I may be gearheads, but the reality is, 75%= of our customers are not
