New U7194 update, new tunes!
BlackCamaro6,2
Post by BlackCamaro6,2 »
06MonteSS wrote:hahaha... fixed 9r20....
sorry, not fixed for 2010 Camaro L99, see :
http://www.diablosport.com/index.php?na ... 665#164665
If you note, that was 9t21a, I have 9t21b posted here, which is the fix ;)
jheckenkamp
Post by jheckenkamp »
when i try to update to 9r20 on my 1 ss it says cant downgrade from 9r16 to 9r20?
jheckenkamp wrote:when i try to update to 9r20 on my 1 ss it says cant downgrade from 9r16 to 9r20?
email sent.
BlackCamaro6,2
I try 21b, but same DTC`s set as in 20 and 21a.
and "....No backup (-11)"
I flashed car back to 19 this works perfect.
New update here:
u7194-9t21c.crom
(1.41 MiB) Downloaded 172 times
Rally2SS
Post by Rally2SS »
And I quote ... "It works !!! Great !!!
No problems with the Predator and the Tune.
Smooth running engine ! Perfect ! "
Just got U7194 for my '10 2SS...updated to 9r21...read this thread...tried to figure out how to downgrade...but it looks like issues were already addressed...
Gonna flash the ecm tomorrow AM. It's my first time messing with auto firmware so I'm just a bit nervous. I've read the forums, manuals and stickys forwards and back....still nervous. Wish me luck!
...and thanks Mike and Lew for being so involved , I feel like I know you guys already!
make sure you start up and let the car run for a couple mins. before you just go and flash it in the morning... after a while, the ecm's go into a "sleep" mode... and if you try to install a tune, you'll get errors... you need to wake it up... heh...
so, before you go to install a tune, start up the car and let it run for a couple mins... then shut it off... then connect the tool, turn the key to ON position, and you'll be good to go...
Rally2SS
Post by Rally2SS »
Worked just like it should!
Got a nice long drive set for tomorrow so I'll see how she feels. 'around the block' test showed lots of improvement, but I can't wait to let the ltft settle in and fine tune it for real! I didn't pull the battery yet, do I really have to?
Rally2SS
Post by Rally2SS »
Holy $#!+!! What a difference! Still a little bit boggy when I stomp on it, but I'm thinking it may be a little rich...I'm planning on logging this weekend and adjust trims. Any other suggested modifications to the 93 Diablo tune? (other than the Lew tune...not yet anyway)
Nice....yeah, a few logs will have it dialed in really nicely.
ftrspeedy
Post by ftrspeedy »
Part of the reason why the shifts in the stock vehicles are so soft is from the engine timing being pulled down. My truck at wot will drop to -8 degrees when shifting...so how wld you firm up shifting on engine side ....huh....
2008 silverado 1500
heavy duty 5.3L
k&n cai
poweraid tb spacer
muffler removed
Edel ceramic coated shorty headers
because, the timing table to pull that timing during the shift, is on the ecm/engine side of the tune file....
so, instead of pulling out timing, the table is adjusted to ADD timing... which in turn gives you firmer shifts... because now, it's not pulling out timing when the tranny goes to shift - it's adding some timing instead...
and it's a separate/different table - it's not the main engine timing table either...
it's actually a spark retard timing table...
Rally2SS
Post by Rally2SS »
06MonteSS wrote: and it's a separate/different table - it's not the main engine timing table either...
it's actually a spark retard timing table... so there...
any more questions?????????????????
Yeah! Who ya callin' a retard tuffguy????? :lol: :lol:
:lol: :lol:
