Boost Delta Questions
I just got my trinity installed on my early 04 dodge ram 2500 diesel 4x4 and I wanted to monitor my boost pressure.. But all I could find is the "boost delta" it measures in psig. Is there just a regular boost setting? Or can someone explain the boost delta to me please? Thank you!
RE: Boost Delta Questions
under synthesized PIDs, at the bottom of the list, do you see it there?
No sir, only thing there is the boost delta
so, when you get the list of PID groups, you dont have a 'synthesized' group at the bottom of the list?
1r08 revision?
1r08 revision?
Yes 1r08 with all the updates. Only one option under synthesized is the boost delta. I don't have just a boost option..
OK, then thats the correct one.
what are you looking for?
that should show boost pressure starting at 0.
The "boost delta" under Synth PID's is gauge pressure in PSI.
When it says like 3.26 is that 3 psi? Or another value?
Yes, 3.26 PSi gauge relative to Atmospheric pressure.
Oh okay cause I am only getting 22 psi at WOT and no smoke out of the performance tune so I'm trying to figure out if I've got a problem or not. I got a Volant cold air intake and muffler delete as far as performance stuff for now.
to my recollection, 22-24 psi is normal.
