Boost Delta Questions
DTatom
Post by DTatom »
I just got my trinity installed on my early 04 dodge ram 2500 diesel 4x4 and I wanted to monitor my boost pressure.. But all I could find is the "boost delta" it measures in psig. Is there just a regular boost setting? Or can someone explain the boost delta to me please? Thank you!
RE: Boost Delta Questions
under synthesized PIDs, at the bottom of the list, do you see it there?
DTatom
Post by DTatom »
No sir, only thing there is the boost delta
so, when you get the list of PID groups, you dont have a 'synthesized' group at the bottom of the list?
1r08 revision?
DTatom
Post by DTatom »
Yes 1r08 with all the updates. Only one option under synthesized is the boost delta. I don't have just a boost option..
OK, then thats the correct one.
what are you looking for?
that should show boost pressure starting at 0.
jimb
Post by jimb »
The "boost delta" under Synth PID's is gauge pressure in PSI.
DTatom
Post by DTatom »
When it says like 3.26 is that 3 psi? Or another value?
jimb
Post by jimb »
Yes, 3.26 PSi gauge relative to Atmospheric pressure.
DTatom
Post by DTatom »
Oh okay cause I am only getting 22 psi at WOT and no smoke out of the performance tune so I'm trying to figure out if I've got a problem or not. I got a Volant cold air intake and muffler delete as far as performance stuff for now.
to my recollection, 22-24 psi is normal.
