I have got a 2007 Silverado that I installed the U7194. The only changes that I made from the 87 octane program was the tire size, rpm limit and speedometer. When I got finished all was well the the ABS and E Brake lights came on. I checked for codes and there were none. Is this a known problem with this model of truck and programmer and if so what is the remedy to fix it?
Thank you for all your help and support!
Scott
ABS and E-Brake Lights
RE: ABS and E-Brake Lights
Do you have non stock tires/gears?
Was your speedo off previously, and is it correct now?
scottvancil
Mike, thank you for your response. I have stock gears. My tire size is 285/65/18. Speedo was correct before and is still correct. When I said I changed the speedo I increased the max speed. I called tech support and they said something about having to download my stock tune and the tune I used to see how to correct the issue. They said that this problem I am having is a common issue. Is this true or is there something I can do with the programmer?
Awesome, i am glad to hear it is related to the speed limiter, we have been guessing that for a while.
Should be a simple fix if you can post up your last tune written and original backup.
Im having the same problem also. Did you get a resolution?
black03silverado
change your aspect ratio of your tire to 60 then set speed limiter 1 to 120mph that fixed mine no problems since
That thing must haul ass. You were going pretty fast when I passed you.
