New Jeep features, new Ram HEMI tunes!
If the latest crom is asking you to downgrade, it will be necessary for the meantime.
- airportdave
TunerTools
The axle locking and sway bar disconnect stuff is rubicon only.
billcampbell
Good Morning . I have a PREDATOR #U7137w/9r12 can not ajust tire size. whatother items can perform(gear change/trans firmness) [email protected]
- airportdave
Bump for Mikel. Any luck with this issue? Tune attached above.airportdave wrote:Here's mine Mike- as noted, big hesitation/pause between the 1-2 and 2-3 shifts. Only parameter mods are throttle boost to 5% and altered speed limiter.
2010 Jeep Grand Cherokee Limited 5.7L, QDII
InTune 91 Octane Tune
(Previous Predator User)
give this a shotairportdave wrote:Bump for Mikel. Any luck with this issue? Tune attached above.airportdave wrote:Here's mine Mike- as noted, big hesitation/pause between the 1-2 and 2-3 shifts. Only parameter mods are throttle boost to 5% and altered speed limiter.
- pcm_68060516ac_perf_91oct_modified_mod.drg
- (73.27 KiB) Downloaded 281 times
- airportdave
- airportdave
Mike- this one is a little better, but there is still a noticeable hesitation/pause between the 1-2 and 2-3 upshifts, especially at part throttle acceleration. This hesitation is not present in the 9R10 tunes I had been running. The rest of the tune and shifting is the best yet though!mikel wrote:give this a shotairportdave wrote:Bump for Mikel. Any luck with this issue? Tune attached above.airportdave wrote:Here's mine Mike- as noted, big hesitation/pause between the 1-2 and 2-3 shifts. Only parameter mods are throttle boost to 5% and altered speed limiter.
Can you look at these shift points again? Thanks!
can you get a log of it happening with this tune?
give this a shot please.
- pcm_68060516ac_perf_91oct_modified_mod_001.drg
- (73.3 KiB) Downloaded 250 times
- airportdave
Johans regular list would be fine.
- Chinpokumon
